NAP-Specific VSA Definitions for 802.1X Network Login contains the VSA definitions for 802.1X network login in conjunction with devices and servers that support NAP.
The Microsoft Vendor ID is 311.
For more information about NAP and the VSAs supported by NAP, please refer to the documentation that came with your Microsoft operating system or server.| VSA | Vendor Type | Type | Sent-in | Description |
| MS-Quarantine-State | 45 | Integer | Access-Accept | Indicates the network access level that the RADIUS server authorizes the user. The network access server (the switch) also enforces the network access level. A value of “0” gives the user full network access. A value of “1” gives the user limited network access. A value of “2” gives the user full network access within a specified time period. |
| MS-IPv4-Remediation-Servers | 52 | Integer | Access-Accept | Indicates the IP address(es) of the remediation server(s) that an unhealthy supplicant moves to in order to get healthy. |
